Carlson 2014 LABSPOT Command
foggyidea
(@foggyidea)
Is there a way to have it label the point with both descriptor and elevation?
I am using the prefix command to label the points descriptors and wonder if there is a quicker way?
Thank you,
Dtp
Posted : May 5, 2015 9:06 am
cptdent
(@cptdent)
After using Carlson all these years and going to all of those classes, this is the first I have heard of the LABSPOT command! It looks interesting. Have to look into that.
Usually to place a symbol and label the control point number, the northing, easting and elevation as text in my drawing on a layer called "Control" I use the Field To Finish attribute block set up. Run field to finish and they areall done. I don't have to hunt them down and label them. (At my age, that's a BIG plus!)
Posted : May 5, 2015 11:37 am
That LABSPOT routine is found under the 3D Data -> Spot Elevations -> Draw Spot Elevation
Posted : May 5, 2015 12:24 pm
foggyidea
(@foggyidea)
You know what? I couldn't find 3d data or the labspot command. I just use labspot and the table pops up. I hadn't heard of it either and it's a great tool! Except I hate the drafting part of my job 🙂
Now if I can make it include the descriptor I'll be a happier man !
Dtp
Posted : May 5, 2015 12:30 pm
plumb-bill
(@plumb-bill)
I think what you are trying to do would be really easily automated with the field-to-finish. It's too involved to go into here, but I would suggest that you begin to look into it. I use it to automatically add all sorts of attributes in text format, and to draw custom symbols.
Posted : May 5, 2015 12:33 pm
foggyidea
(@foggyidea)
Carlson 2014 LABSPOT Command>Plumb Bill
Thanks Bill, I saw something there when I used the Carlson help. I'll check into the F2F a bit more.
I used to use F2F quite a bit but most of my jobs are fairly small, usually less than 50 shots so I got out of the habit. Now it's kind of stale in my noggin.
Dtp
Posted : May 5, 2015 1:05 pm
You must only have the survey module.
What do you get when you issue the "divent" command?
This is found under the 3D Data -> 3D Points -> Interpolate Entity
I'm just curious if there are routines that you have access to that they don't include under the menu items.
To get points labeled with desc. and elevation, I just draw locate points and toggle on those attributes.
Posted : May 5, 2015 1:11 pm
plumb-bill
(@plumb-bill)
OK, you can also use the command "explode_scad" to quickly turn your point blocks in to text entities. Then if you need them at a different scale draw and explode them again.
Posted : May 5, 2015 1:31 pm
cptdent
(@cptdent)
See if this gets you started.
Posted : May 5, 2015 8:40 pm
