Carlson 2013 IntelliCAD - Drawing Buffers
bow-tie-surveyor
(@bow-tie-surveyor)
Does anyone know if there is an easy way in IntelliCAD to draw a buffer line. I have a wetland line that I need to draw a buffer that is 50 feet from it.
Thanks,
Posted : July 17, 2014 3:57 pm
toivo1037
(@toivo1037)
Draw a polyline and then offset it 50'?
or is that not working?
Posted : July 17, 2014 4:42 pm
bow-tie-surveyor
(@bow-tie-surveyor)
Buffer Lines are not the same as Offset Lines...
I believe a buffer line never exceeds the buffer amount (in this case 50 feet). So on the angled out points the buffer with be a curve.
Posted : July 17, 2014 5:04 pm
jacob-wall
(@jacob-wall)
Hi, if you set OFFSETGAPTYPE variable to 1, then your polyline offsets will be with fillet
Quick online search on that system variable found this from http://cadtips.cadalyst.com/2d-operations/adjust-offsetgaptype-system-variable "... change the OFFSETGAPTYPE system variable: 0 is a regular offset, 1 is an offset with fillet, and 2 is an offset with chamfer"
Should work with Intellicad and AutoCAD.
Jacob
Posted : July 17, 2014 5:37 pm
bow-tie-surveyor
(@bow-tie-surveyor)
That works!!!
That works!!! Thanks
Posted : July 17, 2014 6:10 pm
navaran
(@navaran)
Edit>Offset>Buffer Offset
or
BOFFSET at command line
Posted : July 20, 2014 8:26 am
