.cad file extension
(@dan-patterson)
I received some files with a .cad file extension. How do I open these? What program were they created with? I believe they are some kind of shop drawing for a site we're working on. A quick google search suggested they were created with quickcad or sketchcad. I have not found a way to open them using civil 3D or truview.
Posted : April 22, 2015 9:42 am
(@blitzkriegbob)
I haven't seen that extension in a very long time. If I remember correctly, there were quite a few low cost programs that used that file extension. If you really wanted to know which program created the file, you could try to look at the header in Notepad (may or may not work). You probably don't care so much about the origin of the file. Most of those programs usually had a way of saving to different cad formats. Is it possible to ask for it as a dwg file or a dxf file? If not, then I remember, and found again, a program called CadStd ( http://www.cadstd.com/) which should open up a cad file. They have a free version (their pro version still is only $37.50). I think that their free version will export out a dxf file. Not making any promises, but might be worth a shot.
Posted : April 22, 2015 10:42 am
(@dan-patterson)
thanks I will give it a shot
Posted : April 22, 2015 10:58 am
(@bgraham)
From Autocad:
"AutoCAD is not able to open QuickCAD files. Use AutoSketch to open the .cad file and then save it to DWG format. To do this, choose "Save As" from the File menu and then choose "AutoCAD 2007 Drawing (*.DWG)" (or an older format, if needed). The DWG 2007 format is the newest that AutoSketch can save to. AutoCAD 2007 and newer will be able to open this."
Posted : April 23, 2015 12:49 am
