Bearing and distance labels
9 Users
(@john-thompson)
Estimable Member Registered
Leader Label
Can anyone tell me the command for making bearing-distance labels that look like this??ÿ I'm using Carlson Survey with IntelliCAD.?ÿ Thanks.
Posted : 01/09/2022 2:38 pm
(@jon-payne)
Noble Member Registered
Perhaps Annotate-annotate w/ leader.?ÿ I tried using Ortho to make sure the line stayed straight, but didn't seem to be able to do it.?ÿ So you may have to eyeball a nice straight line.?ÿ Then maybe someone edited the arrow length.?ÿ If it is simpler, hopefully someone in the know will tell.?ÿ Looking closer at your post, notice that the 180.50 lines up under the leading degree zero and the other distances are under the second place of the degrees.?ÿ That makes me think it is someone doing some extra work to get the look they wanted.
Posted : 01/09/2022 2:59 pm
(@richard-germiller)
Prominent Member Registered
Just shutting down for the day, I will try to remember to look in the morning.
Posted : 01/09/2022 3:00 pm
(@skeeter1996)
Email Jim Reinbold <jreinbold@carlsonsw.com> He's a genius on Carlson and usually responds very quickly.
Posted : 01/09/2022 3:03 pm
I took a look (I have Carlson with Auto CAD though) I didn't see how to do it, and after Jon's post I tend to agree with him.
Posted : 02/09/2022 6:11 am
(@kevin-hines)
Try grabbing the label grip and pulling the label to the side.
Posted : 02/09/2022 6:15 am
@kevin-hines?ÿ
I know that works in C3D, but I haven't seen it work in Carlson
Posted : 02/09/2022 7:30 am
(@kevin-hines)
@richard-germiller?ÿ
I've never used Carlson, but knew it worked in C3D.?ÿ It was worth a try since there are some similarities between the 2 programs.?ÿ ?ÿAnother case of brainstorming fails, I guess.
Posted : 02/09/2022 7:41 am
(@john-thompson)
Thanks, all of you, for the quick responses. These were made by a lady that used to do some drafting for me years ago. I think she was using Carlson Survey, but I'm not sure which cad engine. Sometimes they fit the space available better than anything else, and I'd like to figure out how to make them.
@jon-payne, You're right, I modified them slightly. They were normally made like the bottom one with the bearing centered over the distance. I scooted the other two over manually because of the fence.
@kevin-hines They are made of two text entities and a leader. Grabbing the grips just moves the pieces individually.
@skeeter1996 I'll email Jim Reinbold. He's been very helpful in the past.
Thanks again.
Posted : 02/09/2022 7:52 am
@kevin-hines?ÿ
That's why we frequent this forum.
Posted : 02/09/2022 12:10 pm
(@sergeant-schultz)
Like this?
Ortho on, draw leader from midpoint, BDLEAD, pick line, snap to end of leader, Justify text as needed, erase leader created in BDLEAD.
Takes a few steps but it can be done.
Posted : 03/09/2022 3:33 am
(@john-thompson)
@sergeant-schultz That's how I ended up making them.?ÿ I'm pretty sure there was a single command to make them, but maybe not.?ÿ I did find out that both the bdlead and annlead commands have options that I didn't know about.?ÿ Thanks.
Posted : 05/09/2022 12:03 pm
(@gdskelly)
Active Member Registered
A slight tweak might be to specify separate layer for the leader from BDLEAD then erase all the BDLEAD leaders as once with LDEL (Erase by Layer)
Could also try a tool on a ToolPalette with the command set to something like:
^C^C_leader;;;n;bdlead;
Posted : 06/09/2022 4:18 pm
(@john-thompson)
@gdskelly That's awesome.?ÿ Thanks.
Help me out with the syntax of all those semicolons and slashes.?ÿ I might find a use for combining some other commands.
Posted : 13/09/2022 2:58 pm
(@gdskelly)
@john-thompson Sure thing... Put a ; where you would hit the Enter key and a where you want to be prompted to pick a point. In the above sample the allows you to pick two points for the leader.
Posted : 13/09/2022 6:22 pm
Share:
