When I use MEASUREGEOM and then select the Angle option, it returns the angle rounded off to the nearest degree. Is there a way to make it more precise?
My dim settings are ok: when I dim label an angle it is precise.
Also, when I open Toolspace/Settings Tab and rt-click on the dwg name/Edit Drawing Settings/Angle the precision is set at 4, so those settings are ok.
Thanks,
Steve
C3D 2010
You have the architect settings clicked!
> Thanks,
> Steve
> C3D 2010
For me, making the change in the "units" settings fixes it.
That did it. Thanks Steve.
