A Starnet question
7 Users
Okay.
I always adjust GNSS and total station simultaneously.
Posted : 25/09/2015 8:53 am
How OSTN02 works
OSTN02 consists of two grids of shift parameters, one for eastings and one for northings. Each of these grids has a resolution of 1 km and covers an area of 1250 km by 700 km. At each intersection of these grids a shift (northing and easting) is given. [hl]Therefore the complete transformation consists of just under two million parameters.[/hl] The transformation at a particular point is interpolated from the shifts given for the corners of the grid cell within which the point falls.
Posted : 25/09/2015 9:03 am
(@squowse)
That's the one, never though of there being so many million numbers in it. The trimble SGF file is 13.4 MB for example.
We have a small subset of the shift grid that is only 1.45 kB
Posted : 25/09/2015 9:14 am
(@squowse)
Dave Karoly, post: 337959, member: 94 wrote: Okay.
What's your workflow ie which program do you use for GPS processing and how do you get the info into Starnet?
likewise the TS data?
I use TBC for static processing. I would also consider using RTK vectors from Trimble Access, not sure how I would bring these in.
I have a custom stylesheet in Access for producing Starnet DAT files from TS data as I was unhappy with the conversion tools of Starnet and also the stylesheet provided on the Trimble website.
Posted : 25/09/2015 9:22 am
I still think it is likely that StarNet could output your final file through the use of the Ground Scale Coordinate file. StarNet will apply a scale, a rotation, and/or to translation to your adjusted results, if desired.
Posted : 25/09/2015 11:32 am
Over the years I have used Leica Ski & Ski Pro, LGO, TGO, TBC, and SPSO to resolve static vectors. All of these could export vectors to a format StarNet could import. These days I am incorporating RTK vecors in adjustments more often than static. These are imported to StarNet using converters that are built in.
For total station data I convert to StarNet using on e of StarNet available converters. These days I'm using StarTDS to convert Spectra Precision Survey Pro raw files. In the past I've used StarTSC to convert Access .dc files to StarNet.
Posted : 25/09/2015 11:38 am
I process GNSS baselines in TBC. Then I export a TDEF file with the post processed vectors in it. If I followed a TBC friendly workflow then I process everything in TBC (essentially first setup on a GNSS point back sighting another GNSS point).
If I'm processing in StarNet then I take the RW5 file I always create on the TSC2 and use the StarNet TDS converter to make the DAT file. StarNet has a GPS import routine under the input menu.
Most of my Surveys are fairly small so I usually hold one OPUS solution fixed and use the others as a check. The GNSS vectors control direction.
Posted : 25/09/2015 11:57 am
