I'm attempting to have Bluetooth output a GGA 1hz NMEA stream for my Android device to use, however whenever I attempt to enable NMEA for Bluetooth ports 1,2, or 3, the Trimble web GUI won't make any changes after hitting "Ok", it just ignores everything I selected and keeps the "output" as " - " on the port summary page. I have factory reset the R10 and the issue remains. Bluetooth seems to work as I can see the R10 BT device on my phone.
EDIT: I figured out the issue, you have to connect the bluetooth device you intend to use before it will let you change the settings.
Posted : 17/11/2023 10:54 am
Because you have not enabled the NMEA outputs option
Posted : 06/06/2024 9:39 pm
