TSC7 and R8-2 Compa...
TSC7 and R8-2 Compatibility help
1 Users
(@taylor81)
I currently have a TSC3 that I use with 2 R8-2's.  I generally run a network rover, and when cell signal is bad, base/rover.
I have the opportunity to purchase a used TSC7 at an affordable price, with Access (2020 I believe).  I am wanting to double check with the crowd to make sure that the TSC7 and the R8-2 would get along, and I would have two available network rover setups.
Can anyone verify that the Bluetooth connection would work between the two, or if it would require a data cable.
My next move would be to update to a newer receiver.
Thank you for your advice.
Posted : 12/05/2023 10:03 pm
