Triumph LS and Veri...
Triumph LS and Verizon sim card
2 Users
adam
 adam
(@adam)
Will the LS work with a Verizon sim card?
Posted : September 7, 2015 9:34 am
shawn-billings
(@shawn-billings)
No. The internal modem is GSM (used by AT&T) and Verizon uses CDMA. For Verizon, I'd recommend using a MiFi device (i.e. Jetpack), or you could also use a Verizon smartphone as a mobile hotspot (they no longer charge extra for this). I've used my phone in this way, but it wouldn't be my first choice.
Posted : September 7, 2015 10:28 am
adam
 adam
(@adam)
Shawn Billings, post: 335424, member: 6521 wrote: No. The internal modem is GSM (used by AT&T) and Verizon uses CDMA. For Verizon, I'd recommend using a MiFi device (i.e. Jetpack), or you could also use a Verizon smartphone as a mobile hotspot (they no longer charge extra for this). I've used my phone in this way, but it wouldn't be my first choice.
Thanks Shawn
Posted : September 7, 2015 10:41 am
adam
 adam
(@adam)
How do you set up the corrections over internet using my base? How do you approach Verizon to get this setup? Cost?
Posted : September 7, 2015 10:44 am
adam
 adam
(@adam)
Another question, why are there 2 SIM card ports?
Posted : September 7, 2015 10:47 am
shawn-billings
(@shawn-billings)
You'll need to get your plan set up for static IP. You only need static IP at the base, but I believe Verizon currently sets up all data devices on a plan to static IP once you pay the one time fee for it. I believe it is a fixed, one time, $500 fee to set up the static IP. This could have all changed, but I believe this is how they were operating a few months ago.
John Evers has actually done this and has walked a couple of people through it. I use TCP, but over a WLAN at my office, not over cellular. For areas with good cellular coverage, I believe a combination of cellular and spread spectrum could replace UHF with quite a few additional benefits (not the least of which is license free and no need for large batteries).
Posted : September 7, 2015 10:51 am
shawn-billings
(@shawn-billings)
Adam, post: 335429, member: 8900 wrote: Another question, why are there 2 SIM card ports?
I've been told that in some parts of the world, you may have a carrier that works well in one part of the country, but not in another. Users there were keeping SIM cards in a box and swapping out as the need arose. Now they can switch from one to the other without fidgeting with SIM cards in the field.
Posted : September 7, 2015 10:53 am
adam
 adam
(@adam)
Shawn Billings, post: 335430, member: 6521 wrote: You'll need to get your plan set up for static IP. You only need static IP at the base, but I believe Verizon currently sets up all data devices on a plan to static IP once you pay the one time fee for it. I believe it is a fixed, one time, $500 fee to set up the static IP. This could have all changed, but I believe this is how they were operating a few months ago.
I just bought the 35 watt radio a couple months ago and may never use it again if I get the static ip. The large battery pack is heavy. I think maybeI should have gotten the 1 watt with internal battery and use it where service is sketchy. And use the static up everywhere else. Verizon service , is great most areas I work. Wonder if they would swap out the 35 radio for the one watt? I have used it only twice.
Posted : September 7, 2015 10:59 am
