trimble r8 model 2
8 Users
Emmanuel
(@emmanuel)
Flatpan, post: 283619, member: 9182 wrote: The one unit does not currently have cmrx so I have been using cmr+. I have tried both the 12.5 and 25 bandwidth on the internal radios with no luck
do you have a copy of winflash supervisor version?
Posted : June 20, 2017 10:18 pm
lee-d
(@lee-d)
I'm not familiar with that but it sounds like something a dealer / service center would have.
Posted : June 21, 2017 6:17 am
detritalgeo
(@detritalgeo)
I am not sure if this will help, but I have had the same thing happen with an R8M2 or R8M3 broadcasting to some GIS gear running an XDL rover. In my case it happened to be broadcasting in CMR which I believe is not GLONASS friendly. As soon as the corrections came in the Glonass SV's were kicked out of the solution because (apparently) there was no correction in the CMR message packet.
As others have said, verify the transmit protocol is CMR+ or CMRx or even try RTCM and see if that behaves differently.
Good luck.
Posted : June 21, 2017 9:10 am
lee-d
(@lee-d)
Great point. CMRx is only supported on Model 2s on more recent firmware versions - it was introduced on the Model 3s.
Posted : June 21, 2017 10:53 am
