Trimble R8-3 Radio ...
Trimble R8-3 Radio Mode Issues
2 Users
Scott Macklyn
(@scott-macklyn)
Hi all,
Currently have a set of Trimble R8 Model 3ƒ??s and having an issue with selecting a radio mode/protocol for each unit.
Current Firmware is 5.37. I can only select modes:
1. Trimtalk v1 @4800bps
2. Trimtalk v1 @8000bps
3. TT450s (HW) @4800bps
The units were converted to the 12.5khz band from the 25khz. Since then the option to select 9600bps has disappeared from the selection box. I have checked in both Trimble Access and WinFlash. Both units still work fine on either the 4800bps or 8000bps but annoying when I try to use other base stations that run 9600bps. Has anyone ever encountered this? I can also note that the option to change from 12.5 to 25 box is no longer selectable from my end (i imagine a dealer could change it but not that I will). I have had initial discussion with Trimble but they arent sure whats happening.
Any ideas would be welcomed.
Thanks Scott.
Posted : April 14, 2019 4:39 am
lee-d
(@lee-d)
What version of Access are you running? At some point 9600 was added back in; I'm pretty sure it's supported on Model 3s. We use 8000 because I know everyone has it regardless of firmware, etc. I could be wrong about the Model 3; I know it's on the R10.
Posted : April 15, 2019 6:19 am
