Son of a @(%)&)^&^$%!
The latest update to TCSM will not allow you to choose US feet for units! Okay, I could live with that but it is a pain in the butt! I can convert US Feet to meters and still get along. I could build a ground projection in meters and it worked fine in a US Feet project. Painful but possible.
However, now I am really stuck. I just tried to build a new ground projection. I have been doing this for fifteen plus years in this software. You just make edit copy the relevant State Plane projection. Then you paste it into your ground projections folder and edit the projection parameters to be reflective of a near ground condition.
I just tried to do that and they have taken the edit-copy, edit-past functionality out of the software! No problem right, just fall back on the old Windows Ctrl C , Ctrl V. THAT WILL NOT WORK EITHER!
Trimble please fix this!!!:-@
I have an older version 2.90(75.00). When I go to Options to verify units I get a message "directory doesn't exist" I know its there. It was hidden. I changed it to not be hidden but I get the same message.
