Trimble 4000se and ...
Trimble 4000se and Ashtech Z-Extreme
(@james-bell)
I am not sure if I am doing this properly but here goes.
I have 2 Trimble 4000se units and 1 Ashtech Z-Xtreme that I would like to use for static baselines. The date displayed on the 4000's is Jan 2000.
I can scan the dat files with the Rinex converter but it will not convert them.
The Ashtech file displays the wrong date. I think this is a clock problem and wonder if anyone knows if or how I could fix them. The Ashtech was purchased in 2001.
Thanks for any help.
Jim Bell
Posted : September 13, 2019 9:09 am
Try this command in conjunction with any other options you are giving the Rinex converter, using whatever the current week number is.
-week 2044
Posted : September 13, 2019 9:48 am
I shouldn't have assumed what converter you are using.?ÿ I use teqc which is a free download, and that week option is required to fix the 2048 week rollover that the 4000 receivers don't deal with.
Posted : September 13, 2019 10:40 am
(@geeoddmike)
To find the GPS week: https://geodesy.noaa.gov/CORS/Gpscal.shtml
Posted : September 13, 2019 10:43 am
 jt50
(@jt50)
When I was still using a pair of Z12 receivers in the early 2000, I remember that it also had the same 1990 date problems in its Rinex files. You don't need to change the dates if you are going to use them as a pair because they will both log at the same wrong dates. I was able to process them and get fix vectors but could not use them together with other newer units.
A firmware upgrade was able to fix them at that time but eventually got the same date error again after the next GPS rollover. They were eventually retired from use.
Posted : September 15, 2019 5:07 pm
(@james-bell)
@jt50
I don't know if the Z12 and Z-extreme are essentially the same and I only have one unit and two trimble 400SE's. I have about reached the conclusion that they are useless. Thanks for your help.
Posted : September 17, 2019 9:38 am
