Topcon Tools v8.2
5 Users
(@topconman)
I am trying to install Topcon Tools v8.2 and I keep having the same problem. It is trying to download a service pack that it cannot find.
It is named...
microsoft visual c++ secure runtime 9.0 (includes atl and mfc) SP1
This is the only thing I can find but it isnt working. I downloaded the version 9.0 ones...
https://support.microsoft.com/en-us/kb/2977003
I tried to manually download this file but it seems the one I am downloading doesnt have everything I need in it.
I am using Windows 7 64bit
I really need this software to work on this pc. I am not interested in purchasing more software or changing operating systems.
Posted : March 15, 2016 9:10 pm
(@felipe-g-nievinski)
So you tried this one:
https://www.microsoft.com/en-us/download/details.aspx?id=10986
Maybe you need to restart the PC.
I'd also try an earlier version
of TT, say 8.1 or 8.0.
Hope that helps.
-FGN.
Posted : March 16, 2016 4:16 am
(@topconman)
That does not work. It will allow you to install that unless you already have Microsoft Visual Studio already installed.
Posted : March 16, 2016 4:27 am
I think the important keyword is "redistributable" -- so try this one instead:
https://www.microsoft.com/en-us/download/details.aspx?id=5582
-FGN
Posted : March 16, 2016 4:31 am
(@jimmy-cleveland)
I seem to remember having to install some of those updates on one of my laptops. I did a google search, and found the service packs it wanted. I thought the process was fairly straightforward.
Good luck,
JC
Posted : March 16, 2016 5:16 am
(@leegreen)
If all else fails. I suggest installing a newer version, ie Magnet Tools 3.3, this should install the proper third party apps needed. Then try to launch Topcon Tools 8.2
Posted : March 16, 2016 5:49 am
(@michael-demarco)
I was installing Carlson survey 2016 and realized the V C++ Carlson installs was also letting Topcon Tools work. Installing these three should do it for you.
There are three VC_dists to install in the zip. It's hosted on google drive
vc_dist.zip
Posted : October 20, 2017 12:00 pm
A colleague was able to resolve this issue using the "VisualCppRedist AIO" utility:
https://github.com/abbodi1406/vcredist
Hope this helps someone facing the same situation.
Posted : October 20, 2020 7:52 am
