So, are my HiperLit...
So, are my HiperLite+s......
8 Users
(@sergeant-schultz)
Noble Member Registered
now dead meat?
Asking for a friend.
Posted : 08/04/2019 10:50 am
(@marv-d)
Active Member Registered
It may be firmware date related,, Topcon says "End of Life" and wants us to throw them away and spend for new. But Topcon can kiss my ......?ÿ I have my old Hiper GGD's and all but one (of 4)?ÿ old Legacy-e receivers gathering files. It appears the 'windows' file date is 1999 when downloaded,?ÿ BUT, the Data 'in' the file has the correct date. I am trying to get time to set up and see if they work RTK, but I have heard the roll-over is not going to have a 'big' effect on RTK work. I sent a short file to OPUS-RS and it didn't kick it back, but was not enough SORS stations reporting back yet to process.?ÿ
?ÿstanding by.......
Posted : 08/04/2019 11:23 am
(@totalsurv)
You need to check what the board in the receivers are. Alot of the Hiper models use the board HGGDT.
My Hiper+ is marked end of life but it has the HGGDT board. I was able to upload the firmware and it is working fine.
Supported Products
Systems
ƒ?› Topcon HiPer Pro, HiPer+, HiPer Ga, HiPer Gb, HiPer XT, HiPer Lite+, HiPer GL, HiPer M, Map HP, Map-RT, HiPer AG, IP-S2, Legacy-E+, Odyssey-E, Odyssey-RS
Posted : 08/04/2019 11:56 am
(@bulgariasurv)
New Member Registered
Can you please share the name of the firmware u had upload to your receivers, and tell us also how can we check the model of the boards ?
Posted : 18/04/2019 6:00 am
(@mitchptd)
Estimable Member Registered
You can find all the information here : www.gpsrollover.com
Also here is the link with how to update them, and how to check which board version they have.  You will have to create a logon with them to view it.
https://www.topconpositioning.com/support/article/tru-topcon-receiver-utility-upgrading-gnss-firmware
Posted : 18/04/2019 6:58 am
(@bulgariasurv)
i tried but it requires a registration of the product, which i cant find in the database of the site (neither with serial number or manually selecting the model). The model is Hiper gdd and the firmware is end of life? So my question is : is there a way to make it work properly without buying new receivers ?
Posted : 19/04/2019 6:22 am
(@russ455)
Use tru and use the receiver managing application. ?ÿ ?ÿThe info tab will have the board model. ?ÿ Post up an email address and We can get you the proper firmware.
Posted : 19/04/2019 1:24 pm
(@david3038)
Reputable Member Registered
I updated mine a few days ago and did not have to register. Tested today between thunderstorms and worked fine. Ran a rapid static session and will upload Monday to check. Fingers crossed
Posted : 19/04/2019 3:12 pm
(@bulgariasurv)
Receiver - Topcon Hiper GGD
Board Version: HE_GGD_2, HE_GGD_3 and HGGDT_7
e-mail: llkonsult@mail.bg
Posted : 22/04/2019 6:10 am
New Member Guest
Hello. If anyone has the firmware of Topcon Hiper GGD, please share it with me. Thanks!
Posted : 27/08/2023 4:56 am
Share:
