Site calibration fr...
Site calibration from Access to SCS900?
(@beavers)
Is it possible to do a site calibration in Access and then transfer it to a controller running SCS900?
I see in the SCS900 manual where you can transfer the calibration to a GS900 as a CFG file. I don't see any CFG files in Access though.
Thanks for any help.
Posted : December 8, 2014 7:51 pm
(@christ-lambrecht)
Hi,
no experience here with SC900 ...
Maybe xml is the way to go.
In Access you can export to Trimble JobXML (Job|Export|Fixed Format Files)
Don't know about SC900 but hope it will import this file type.
Christof.
Posted : December 8, 2014 10:45 pm
(@todd-madeen)
No easy way inside of SCS900
I'm not sure about the survey edition of Buisness Center but with the Heavy Construction edition you can pull the .job file and convert it.
I have had problems if you have recorded points after localizing/calibrating. To bypass this just export the PNEZD and LLH data as a points file then you can bring them into TBC-HC and "marry" them then export a DC file.
I believe you need the field data module to do this in TBC-HC.
If you send me those two point files I could send you back a .DC
Posted : December 8, 2014 11:24 pm
(@beavers)
Grading contractor was having trouble with his site callibration. I was hoping there was an easy way to transfer it from my DC to his.
We got it figured out anyway and he's up and running. Thanks for info guys.
Posted : December 9, 2014 9:33 am
