process static data
5 Users
(@ashraf)
if i observation network points in static data day by day the best thing that i process Each day is separate by itself or process all days in one time
Posted : 26/11/2018 9:48 pm
It should not matter
The data will be processed according to the time of collection.
Posted : 26/11/2018 10:10 pm
(@sireath)
When I used TBC V2.7, with multi day processing.?ÿ The baseline processing would hang. When I used TBC V4.00 there would not be any problem processing multi day baseline.?ÿ
I personally feel that if the stations are the same for multiple days, there should at least be adjusted simultaneously.?ÿ
Posted : 27/11/2018 1:30 am
Some days will have better conditions than others.?ÿ If the software applies proper weights according to the quality of the data, processing all together can give a slightly better answer than the mean of separate solutions.
On the other hand, the software may (like OPUS) limit the number of CORS used.?ÿ Using the same CORS for all the time could risk degradation of the accuracy if the CORS had different weather conditions at different times.?ÿ Separating into shorter runs would reveal such problems.
Posted : 27/11/2018 5:32 am
(@jitterboogie)
You will develop a work flow based upon the results you need.?ÿ The IGS final orbits data won't be at the URL supplied in an old version of TBC so you will need to research that once you start processing.?ÿ Overall, The newer versions of TBC( not newly released 5.00) seems to handle the task better than old " paid for" version because they improved the modeling and processing code too.
Posted : 27/11/2018 8:18 am
