Chat Conversation Start
6:04PM
Im bein an idiot a while ago. I was configuring my R10 using the webUI but i input a password on my network configuration without changing the username. now when i reboot the R10 i can't access the webUI because it needs the username and password for the site. anybody can give an information about the default username of the "network configuration" of R10? i would be much thankful for the help.
I'm betting that the R10 has a reset procedure that'll allow you to start over with the network config, but I'll note that product designers don't always cover their bases in this regard. I learned this the hard way.
The Netgear AC791L mobile hotspot allows the user to disable both the DHCP server and the front panel access, which means that upon reboot you've got no way to configure the device. Most products like this have some kind of mechanical reset procedure (e.g. a paper-clip-through-the-pinhole switch), but Netgear left that off of this one. Verizon had to issue me a new one after I stumbled into that mess.
squowse, post: 423537, member: 7109 wrote: Yes I have had to do this on an R10.
Did you have the same problem on the webUI? the situation is that when i tried to connect to 192.168.142.1 it ask me the username and password. but as i remember i did supply admin and the password. the password is changed the same as what i used on my R8S webUI.
Jim Frame, post: 423535, member: 10 wrote: I'm betting that the R10 has a reset procedure that'll allow you to start over with the network config, but I'll note that product designers don't always cover their bases in this regard. I learned this the hard way.
Hi Jim!
You mean you replace the wifi adapter inside your Trimble R10?
Emmanuel, post: 423544, member: 12658 wrote: Did you have the same problem on the webUI? the situation is that when i tried to connect to 192.168.142.1 it ask me the username and password. but as i remember i did supply admin and the password. the password is changed the same as what i used on my R8S webUI.
I had the same problem that i could not login. So I reset and started again.
Jim is talking about a different device where he had the same problem, but could not reset.
squowse, post: 423546, member: 7109 wrote: I had the same problem that i could not login. So I reset and started again.
oh i see... ill try your solution and let you know... thank you
oh man! thank you so much! it works! i drained my battery and brain for almost 2 hours figuring out how to fix my problem.... than you so much again!
squowse, post: 423552, member: 7109 wrote: no probs
https://www.trimble.com/globalTRLTAB.asp?nav=Collection-90570
how about for R8s?
Hi bud! i have a question regarding the setup between Trimmark 3 and my base R8s and my rover R10. i purchased my trimmark 3 on ebay months ago then i try to use it now but my problem is that the trimmark 3 installed frequencies is totally not a single the same as the preload frequencies on my R8s and R10. i've tried to configure the trimmark as 464.75000 and add a frequency of 464.75000 on my R10 but the the internal radio frequency my R8s is 445.50000 because i can't add a new frequency on a "base" mode.
my question is, do i need to make the radio frequency of my base R8s internal radio the same as the trimmark 3 setup as base with no repeater so i can connect on my r10 rover?
Emmanuel, post: 433158, member: 12658 wrote: Hi bud! i have a question regarding the setup between Trimmark 3 and my base R8s and my rover R10. i purchased my trimmark 3 on ebay months ago then i try to use it now but my problem is that the trimmark 3 installed frequencies is totally not a single the same as the preload frequencies on my R8s and R10. i've tried to configure the trimmark as 464.75000 and add a frequency of 464.75000 on my R10 but the the internal radio frequency my R8s is 445.50000 because i can't add a new frequency on a "base" mode.
Sorry I haven't had much to do with external radios. Maybe you configure the frequency after you connect to the external radio?
squowse, post: 433186, member: 7109 wrote: Sorry I haven't had much to do with external radios. Maybe you configure the frequency after you connect to the external radio?
nope coz i need to connect the trimmark 3 on TSC3 when im setting up the base radio link and after that thats the time im going to connect the lemo 7pin connecting the base and the trimmark 3. i already contact sitech to provide me a frequency file to update the frequency of my trimmark 3 same as my base and rover, hope it will work this time. i dont have problems with internal radio they connect right away but R8s effective range is only 3km and i need to boost the signal to get me far more coverage. in my country, internet signal on mountain side is hard to get so i need the extended radio signal just in case.
You are SOL with that radio unless a dealer can reprogram it. But I don't think TM3s in the 430 - 450 band support 450 - 470.
Lee D, post: 433234, member: 7971 wrote: You are SOL with that radio unless a dealer can reprogram it. But I don't think TM3s in the 430 - 450 band support 450 - 470.
yeah sitech told me to that they are going to send a frequency file for me to upload on the TM3. my R8s, R10 and the TM
yes your right and im a lucky idiot because my R8s and R10 is within the range of the TM3 i purchased. but do you know anyone knows how to create a Frequency file for my R8s and R10 which is exactly the same as my TM3?
