need Help on Topcon...
need Help on Topcon Hiper Hardware issue
(@sbaksso)
Trusted Member Registered
@antcrook ok thank you I will try to connect that cable and see the result. Thanks I really appreciate your help.
Posted : 18/06/2020 12:18 pm
(@antcrook)
Reputable Member Customer
@sbaksso I usually remove all the cards and also the antenna, then connect the cable to the antenna and feed it back through the small hole on top of the housing, replace the antenna, then carefully slide the cards back in making sure you don't dislodge that gnss antenna cable. You also need to be careful not to break that white cable when you remove the cards, which is the bluetooth antenna.
Posted : 18/06/2020 12:46 pm
(@sbaksso)
@antcrook yes I think we missed that, the longer cable must be connected to the gnss antenna connector, Will try to fix this tomorrow and let you know if it worked. Thank u ??? for your precious help.
Posted : 18/06/2020 1:14 pm
(@sbaksso)
@antcrook I just follow your instructions, my receiver track satellites now! thank you very much for your time and your efforts, you saved my receiver!
Posted : 18/06/2020 2:19 pm
(@tazsurveyor)
Good stuff antcrook
Posted : 18/06/2020 2:53 pm
Share:
