Magnet Tools GPS+ S...
Magnet Tools GPS+ Static Processing
8 Users
Jerry Paraka
(@jerry-paraka)
This is one of the problem that I also encounter when processing GPS raw data (RINEXED Files). we need to really think about the vector line about from and To. In every perspective of GPS surveys, Network adjustment is very important component of acquiring the accuracy to it specification. The differential correction is perform from the base station to the rovers. The accuracy of the base station determines the accuracy of the rovers position. NOT from the rovers to the base.
with that understanding that I have, I tried to fixed the vector the vector line but i couldn't. Please I need help from anyone
Posted : April 5, 2021 10:45 am
Jerry Paraka
(@jerry-paraka)
@jt50
How did you changed it to 0000 0000 0000?
Eg.The rinexed file here is log0064b10
I tried but I didnt find a solution. Please assist
Posted : April 5, 2021 10:52 am
Artie Kay
(@artie-kay)
Lee, I think the confusion is in the terms used in Magnet Tools. CORS Rinex files when imported become 'bases' and your static obs station becomes a 'rover'. Points appear under 'Point to' and 'Point from' columns but it doesn't appear to matter about the direction. The critical item is the choice of 'Both' (horiz and vert) or 'None' in the 'Control' column for each station.
Posted : April 8, 2021 2:56 pm
