Looking for cheap G...
Looking for cheap GNSS board
2 Users
afcckr
(@afcckr)
I am looking for cheap GNSS board. Which must satisfy these requirements:
  • Must output raw observations and ephemerides.
  • Observations must include L1,L2 C/A Psuedorange and Carrier Phase.
  • Must have external antenna connection.
  • Output Protocol must be in Serial (RS-232 or TTL) or can be converted to Serial easily.
  • Output Data Format must be well documented or well-known format.
Any suggestions?
Posted : May 27, 2022 2:23 am
jitterboogie
(@jitterboogie)
Try Sparkfun:
https://www.sparkfun.com/news/4662
Posted : May 27, 2022 5:19 am
afcckr
(@afcckr)
@jitterboogie Couldn't see any external antenna connections. Beside that, RTK Facet is complete product. I am spesifically looking for board or component. But i found the board inside of it, (I think). it is overqualified.
Posted : May 27, 2022 5:43 am
jitterboogie
(@jitterboogie)
@afcckr
Yeah, I?ÿ was just pointing you to the sparkfun site.?ÿ You can?ÿ build that unit with their parts or purchase it completed.
I guess you're seeking used old tech for your project?
What wheel are you trying to reinvent?
Posted : May 27, 2022 6:29 am
afcckr
(@afcckr)
@jitterboogie I am not trying to reinvent the wheel or i am looking for used old tech ???? I wrote my own double differencing code which utilizes different approach on determining Delta Z component of the baseline. I am tring to test them on common receivers. So far, I tested on Topcon (Legacy-E and HiPER GGD) and South and results were better than their internal real time solutions. Buying whole kit or overqualified board is bit unnecessary for my research.
Posted : May 27, 2022 7:44 am
jitterboogie
(@jitterboogie)
@afcckr?ÿ
Duly noted.
Good luck and keep us posted.
Posted : May 27, 2022 8:10 am
