I am trying to use a couple of 4600 receivers to establish some base lines.?ÿ I have collected the data, run through "fixweek" and end up with an error in the week when I process the DAT. file in WinTEQC.?ÿ The receiver defaults to 8-2000.?ÿ I know I've seen stuff in the past about changing the date, but I'm not finding it in my searches.?ÿ I think I need to add 1040 weeks but not sure how.?ÿ Also, is there a way to update the date in the collector? Thanks for any help because my head is getting sore.
There are some solutions to backdate the files, mine works only once you converted your data to the Rinex Format.
latest version of RinexDates is 1.8 but since last leap-day that doesn't work anymore, you have to use RinexDates 1.7 again for a correct date offset.
See the post in the link below.
https://surveyorconnect.com/community/software-cad-mapping/rinexdates-1-8/paged/14/#post-521245
I don't know if that will work if the date in your dat-files is wrong.
