First GPS 3 Launch ...
First GPS 3 Launch Tomorrow
12 Users
base9geodesy
(@base9geodesy)
OPUS uses only the published values.?ÿ How well CORS may be performing in the solution will show up in the peak-to-peak values for the latitude, longitude and ellipsoid height components.?ÿ As long as I'm on this topic I will encourage all OPUS users on this board to be VERY cautious about accepting the uncertainty for the GPS-derived NAVD 83 orthometric height.?ÿ They are pretty optimistic. ?ÿ The OPUS utility does not use the uncertainties from the GEOID12B model which I have found to usually be 2-7 cm higher than whatever OPUS says the orthometric uncertainty is.?ÿ I posted this to them back in September.?ÿ They have acknowledge the error but have yet to make any correction in the utility or post anything on the web site.?ÿ
Posted : December 27, 2018 6:02 pm
We had a discussion here about the lack of realistic geoid uncertainties quite a while back.?ÿ The other point that came up then was the incorrect way the 1.6... factor between pk-pk?ÿ and rms was applied in the formula.
Posted : December 27, 2018 7:07 pm
