I had a battery die and have two Trimble t02 files just under 2 hours. Does anyone know of a way to combine the 2 t02 files? Do I need to convert them to rinex? And then is a way to combine them? I am thinking there is. It??s just been a few years since I??ve had to mess with this kind of stuff. Thank in advance.?ÿ
While I would be tempted to try to combine the files using copy /b via the command line, teqc would probably be best.
from?ÿ https://www.unavco.org/software/data-processing/teqc/tutorial/tutorial.html#sec_04
And if you don't like command-line applications, there's always WinTEQC.
Makerofmaps,
Did you get the files combined and processed successfully??ÿ
Yes the WINTEQC worked. I had to do combine two files then the third. Then they asked for the navigation files. The .n I just did a little cutting and pasting with this three files and it did the trick.?ÿ
Learn something every day....
Having the same problem... bad battery on a project 2 hours away and trying to combine a couple .t02 files. The software is giving me an error when I try to load either file.
I'm curious if anyone has used this software lately? I suspect it's not updated often and the current file structure doesn't play nice anymore?
Also, I'm wondering if maybe I convert to rinex first and then try combining will work.
