Win 10 / Acad probl...
Win 10 / Acad problem
5 Users
(@sergeant-schultz)
After upgrading from Win10 64 ver. 1703 to ver. 1709, Acad 2006 crashes when I try to open a 2nd drawing file. MS support says, "too bad, so sad, buy new Autocad",
but I don't want to do that, obviously. Any thoughts?
Thanks,
SS
Posted : November 3, 2017 5:46 am
(@ozzy84)
need some info, ie.. same acad session? open 2nd drawing first, works? etc...
will help all trouble shoot if you can give more info.
Posted : November 3, 2017 5:53 am
(@sergeant-schultz)
Start Acad, (Actually Carlson Civil Suite 2012 in Acad 2006), File>Open.. Survey 123.dwg. Then: File>Open.....and that's as far as it gets before Unhandled Exception Error Dialog and Acad shuts down. Doesn't matter what dwg, of several thosand, is first, it only allows one open dwg.
Posted : November 3, 2017 6:05 am
(@flga-2-2-2-2-2-2-2-2)
I'm still using LDD2006 on win 10 with whatever version Microsoft has decided to install, and this solved everything. Don't know about Carlson though, never used it.
http://www.longbowsoftware.com
An alternative: https://www.cnet.com/how-to/stop-windows-10-from-automatically-updating-your-pc/
Posted : November 3, 2017 6:06 am
(@sergeant-schultz)
FL/GA PLS., post: 453813, member: 379 wrote: I'm still using LDD2006 and this solved everything.
What version Win 10? 64 bit?
Posted : November 3, 2017 6:08 am
Sergeant Schultz, post: 453814, member: 315 wrote: What version Win 10? 64 bit?
1. Don't know I'm on android now.
2. Yes 64 or 32 (I'm on 64)
Posted : November 3, 2017 6:20 am
(@bstrand)
Sergeant Schultz, post: 453805, member: 315 wrote: After upgrading from Win10 64 ver. 1703 to ver. 1709, Acad 2006 crashes when I try to open a 2nd drawing file. MS support says, "too bad, so sad, buy new Autocad",
Thanks,
SS
This simple solution would seem to roll back to a previous version of Windows.
Posted : November 10, 2017 2:42 pm
(@sergeant-schultz)
BStrand, post: 454965, member: 13049 wrote: This simple solution would seem to roll back to a previous version of Windows.
Actually, i'd already done that prior to making the OP.......but thanks, anyway.
SS
Posted : November 11, 2017 6:44 am
(@richard-imrie)
Maybe this relating to graphics:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-crashes-when-multiple-drawings-are-open.html
Have you got all the service packs and hotfixes installed for AutoCAD 2006.
We use AutoCAD Civil 3D 2015 and while on the whole it is great with Win 10, recent OS updates have generated a couple of issues, like F8 ortho on/off freezing (although Autodesk have put out a workaround fix to that).
Posted : November 11, 2017 11:22 am
(@sergeant-schultz)
Happy again. Bitched to MS about this issue, and voila, latest update did not break Acad 2006 - at least as far as my OP is concerned......
Posted : November 18, 2017 7:53 am
