Ring Ring
5 Users
(@hollandbriscoe)
So I get a call the other day to quote a ~40 acre job about an hour and a half from me. After I look it over and get everything worked up and the quote comes out to $24,000. Mind you this property has a 1000' elevation difference from front to back,?ÿ is heavily wooded and I figure its going to take me three weeks to do everything since I work solo. I call the client back and he about has a stroke at the price. He then calls me back to make sure that he heard me right and that I had not said $2400. He was apparently expecting the cost to be between $2500 and $3000. I told him that if he found someone to survey that property for that price that he needed to run since that survey is being done on a bar stool. I guess surveys are cheap in Fort Meyers, FL where he is from.
Posted : 18/01/2022 9:49 am
(@richard-germiller)
But my realtor told me... (or someone at the Planning Department, bartender or some other expert in what things should cost)
Posted : 18/01/2022 10:03 am
(@andy-bruner)
You can bet there isn't 1000' difference in elevation around there.
Andy
Posted : 18/01/2022 11:35 am
(@flga-2-2-2-2-2-2-2-2)
Posted by: @hollandbriscoe
And practically flat, as is most of Florida. If he finds a Surveyor that will survey 40ac in FL for $3k, well, I'll just shut up here and wish him good luck...rather than be subjected to litigation from whomever he employes.
Posted : 18/01/2022 12:13 pm
@flga-2-2?ÿ
I didn't think there was 1000' vertical in all of FL (isn't the highest point some man-made thing in Disney @ about 200'?)
Posted : 18/01/2022 1:22 pm
(@hollandbriscoe)
Posted by: @richard-germiller
@flga-2-2?ÿ
In Florida no, in the mountains of NC yes.
Posted : 18/01/2022 1:29 pm
Florida is flat.?ÿ To get a 1000' elevation difference would require going to a depth of 655 feet BELOW sea level.
https://en.wikipedia.org/wiki/Britton_Hill
Posted : 18/01/2022 1:39 pm
@holy-cow?ÿ
Yup, and running a bench loop is easy. ?????ÿ
Posted : 18/01/2022 2:12 pm
