Need help with prop...
Need help with property line marking
13 Users
(@gordon-svedberg)
There is also a prism which shows an image both left and right (and forward), as you move on line, the images align with each other.
Posted : 09/01/2023 1:30 pm
(@fairbanksls)
Ask the surveyor to stake the line for you. With trees in the way he will have to traverse between the corners occupying points where he can see each location along the line that require marking. Thatƒ??s about the only reliable way as trees will need to be removed to make way for the fence and you have to be certain they are your trees to remove. If they already did the boundary, itƒ??ll cost less than starting from scratch. Good luck!
^^^^^^ This is the correct way. ?ÿ
I wouldnƒ??t recommend that a property owner use a method that I wouldnƒ??t use. ?ÿThe range poles may have been ƒ??good enoughƒ? 50 years ago but not today. (IMHO) Mature hardwood trees arenƒ??t cheap and neither are fences.
Posted : 09/01/2023 4:38 pm
 jph
(@jph)
Totally agree
Posted : 10/01/2023 8:36 am
