Using StarNet - What Does a 1" Direction Error Mean - Trimble S9 Total Station
11 Users
(@squowse)
Rankin_File, post: 445133, member: 101 wrote: I think the only time I've used DN is with resections- It's the way Star*TDS reduces a resection in a survey pro .Raw file.
In those cases, I've usually ended up with a direction value the same as my angle value.
Do any of the Star*Net gurus have other instances where they use it?
do you mean DN or direction sets (DB,DM and DE).
I prefer direction sets, although the Leica and Trimble converters don;t create them as much as I would like. Sometime I have to manually edit them.
The direction set applies an estimated error to each HA measurement regardless of what the notional "backsight" is. Ina dense network I often have multiple backsights/foresights/sideshots that are basically the same to me.
Posted : 05/09/2017 9:29 am
(@larry-scott)
T2, T3 pencil and paper notes? Yeah, DB DN DE. I know no other. First set, backsight reading is always "whatever it happens to be". Second set, advance the plate enough, and pay no attention to setting minutes or seconds.
DB DN ... DN DE.
Best part is adjusted output in the listing is in plate readings. Great way to find a minute bust.
I'm still unsure if the value in options for directions is Std Err or Std Dev.
Posted : 05/09/2017 2:19 pm
