Today's Monument
paden cash, post: 432092, member: 20 wrote: PTO shafts generally have the larger square keyway splines.
Is this a pto shaft ?? It's a low quality photo but the teeth project out farther than the shaft diameter.
Shaft diameter is 1.9"
Posted : July 12, 2017 5:16 pm
Many times pto and axle shafts were smaller in diameter than the splines to reduce the amount of steel and/or increase the capacity of the lubricant case.
Posted : July 12, 2017 6:01 pm
Here's a 1000 rpm PTO shaft.
Note how the splines extend much farther than the shaft you found. Also, there is the groove where the locking pin locks the drive shaft onto the power shaft.
Posted : July 12, 2017 7:29 pm
Here is a John Shaft
Note the badass attitude and cool seventies facial hair. Also, this cat won't cop out when there's danger all about. Can you dig it?
Posted : July 12, 2017 8:29 pm
Thanks Cow. I suppose I am thinking of a much older type of pto shaft. I was thinking of something like this:
http://www.ebay.com/itm/E5NNA728AA-Ford-New-Holland-Tractor-PTO-Shaft-2600V-2610-2810-2910-3000-/231099551083
.. or maybe this type ???
http://www.agkits.com/ford-pto-shaft-htd8nn7a684ba.aspx#.WWdIrzOZNGM
Posted : July 13, 2017 2:09 am
(@sergeant-schultz)
Around here, that's an IPF. Unless you set it, then it's an IPS.
Posted : July 13, 2017 3:13 am
(@flga-2-2-2-2-2-2-2-2)
That's a "Leaning Shaft" better contact McMillan. 😉
Posted : July 13, 2017 3:50 am
Interesting. That would be inside the tractor. Not familiar with those. The one in my photo is the standard final shaft, exiting the tractor for connection to powered implements via the pto driveline(s).
Posted : July 13, 2017 5:54 am
