> How is a found property corner less accurate than a set control point? I don't see a problem with occupying a found point. Am I missing something or is this just some weird OCD surveyor thing?
Neither. I generally get more bang for my buck from a control point than occupying the corner.
It's very true. I've seen lots of birds sit on fences I've built and voila, there are trees where there once was field. Now I spray Eraser to kill the trees.
> The idea was that "radial surveys" were illegal because you had no positional tolerance calculation on the corner.
Positional tolerance for a sideshot is calculated by propagating the standard errors of the sideshot measurements from the error ellipse of the control point.
If I can't set up on it
> i don't set an instrument up on something that isn't control quality
I don't either, but my definition of "control quality" varies with the situation. Sometimes it's an A-Order mark, and sometimes it's an X made with a red pencil on a sidewalk. And sometimes it's nothing at all, as when I resect my position.
Correct. You can calculate it on the assumption that the standard errors are a true representation of the actual statistics. It is really good to have redundant data as evidence the measurement wasn't blown.
Like I said, the "idea" was that. Not that it couldn't be overcome. 🙂
Ultimately, I agree (in part) with their rational, so long as one has a closed figure or a "check". The setting two points and surveying a tract left a lot to be desired. Not enough degrees of freedom.
