@ramses?ÿ
The RH12 requires the communication side cover, which also contains a standard Bluetooth module, to connect to the TPS1200.?ÿ The side cover adds the contacts for the RH12/RH16/RH17 to the TPS1200.
@john-putnam Yes actually that is exactly where the problem lies. But unfortunately you said in an earlier comment that it cannot be done by individuals. Did I get it correctly? Also, the side cover is absolutely nowhere to be found on the internet for sale.
@ramses Thanks for the reply and for sharing your thought. Yes actually I was planning on buying the RH handles and a Leica CS15 controller in the beginning. That all did not happen because I do not have the GSD01 side cover which is required for installing the RH radio handles (the GSD01 side cover has the pins required for the installation of the RH handles). I have tried to search the entire internet to find one on sale but nothing.
You can still use the CS15 w/extended range blue tooth (CTR16).?ÿ You just need to get the external version of the RH16, the TCPS29 radio and a Y-cable.?ÿ The TCPS29 connects through the lemo port on the TPS1200.
I actually have a CS15 that I may be willing to part with.?ÿ I also have a RX1220T / TCPS279 which is the original setup for your 1200.
I'm trying to connect the Bluetooth Leica 1205+ total station but it gives me connection time up can you tell me how you managed to connect it
