I recently acquired a couple fully functional NA2002 and NA3003 ?ÿDigital levels. They are 3.3 ?ÿVersion software, From what I understand version 3.2 and 3.3 are able to transfer data via serial cable directly to the computer. As these are no longer supported by Leica I was not able to get much support that way, wondering if anyone remembers how they used to do Their data transfer?
Manual Page 83-84 (7-9 to 7-10)
Manual Digitallevels NA2002/NA3003 V3.3
Mayby use some serial port logger software at your PC.
Back in the day when I used Leica digi levels, they had an onboard rec card and an external card reader to transfer the data.?ÿ That was about 20 years ago.
Back in the long long distant past we used to use a program called 'Kermit' to transfer serial data between various devices.
I also built a number of systems to capture and log laboratory data using 'Procomm+'
For a while there was an accessory called 'Windows Terminal' that sort of the did the same thing - only not as reliably.
Haven't seen them around for years - not sure if they even still exist.
Wow those are the Wild versions.
We had a set of those exact devices when I worked at an aerial mapping company. Would be funny if you got them from that group on ebay.
Good luck and great find!
Found a copy of the sales brochure on-line http://www.meetcentrum.nl/files/Wild%20NA3003.pdf
I note it mentions using the GIF10/GIF12 for data transfer
