What measurement exactly is entered in the Leica instrument itself for the Reflector Height?
From the bottom tip point of the prism pole up to the bottom of the Leica GMP-111 (red/orange) mount?
Or do I add the 50mm (stamped) from bottom of Leica GMP-111 up to vertical center of the prism itself?
When selecting/setting the reflector in the instrument itself, does it add this 50mm maybe?
Same for the other Leica reflectors too? I.e. 360 Prism?
Posted : 06/01/2023 2:47 pm
The center of the prism is a zero target height for all prisms.?ÿ If you set the GMP-111 on a surface then you would enter a reflector height of 50 mm.
Posted : 06/01/2023 3:47 pm
