If someone could share with me the "System.ram" file from the Leica RX1250TC controller, I could say for sure if the missing serial numbers and device type is related to the RAM disk
If I have to do this method, will I have to have a copy of the firmware it is currently on v8.10? (Which is no longer avail on Leica MyWorld) Or can I use the last version provided v9.03. (Maint date 11/23/2011, but the maint date end on device says 2/9/2010?)
I'm guessing if I try to update to v9.03, it will not register as maintenance is ended... and I do not have v8.10 to get it back it will brick it?
It would probably be helpful to somehow have the original recovery cd which I do not have. Any way to use the v9.03 latest fw after main date end?
I could extract keys and things from TPS1100 series with Leica Instrument Tools, but TPS1200 is not showing up in drop down menu so cannot.
Thank you for the help!
Tim
Hello everyone,
I'm having the same problem as you all.
I have an RX1250tc, and it boots with the black and white software in GX1200 mode.
Have you managed to find a solution?
Thank you.
Hola a todos, me gustaria poder resolver el problema firmware 3.0
fin de mantenimineto 06/10/16
meas engine 2.127
gracias
