Hemisphere S320 receivers - configuration with external 35W radio
2 Users
(@big-al)
Because I was having recurring problems with my Topcon Hiper Pro receivers, I purchased a pair of Hemisphere S320 receivers, otherwise known as the Carlson BRx5.?ÿ More channels, newer hardware and software, and (I thought) better integration with SurvCE.?ÿ It's been a mixed bag so far.?ÿ The pair of receivers work fairly well using the internal radios (Microhard NL400), and seem to handle canopy situations just a little better than the older Hiper Pros.?ÿ But internal radio range is predictably limited.?ÿ
I've spent quite a bit of time trying to get my external 35W radio to boost the range.?ÿ It is a JAVAD HPT435BT.?ÿ I can get the base to send the ROX corrections out (through Port A) and the TX light on the Javad radio lights up.?ÿ But I can't seem to get the corrections from the Javad radio to the rover.?ÿ I've checked to be sure that the S320 base and Javad radio are operating on the same baud rate, and they are.?ÿ The fact that the TX light is illuminated makes me think that the connection between the S320 base and the Javad radio is OK.?ÿ As for the connection between the Javad radio and the S320 rover, I have set each to the same radio frequency to match my FCC license.?ÿ I have also updated the GNSS firmware on the S320 receivers to MFA 5.9Aa08.?ÿ However, I cannot seem to update the firmware for the radio from "5.174-PC" to the latest "5.182-PC".?ÿ I've tried updating the radio firmware directly using SD card method, and have additionally tried Hemisphere's "Autoloader" software, and the "Right Arm" software.?ÿ No method has been successful in updating radio firmware.?ÿ I think the radio firmware may be important, as from interacting with Hemisphere support staff, the later radio firmware allows for use of additional protocols (PC2, PC5, and TRIMTALK protocols).?ÿ Presently, the available protocols are only PC1 and PC3.?ÿ?ÿ
If anybody out there has been through something like this, and has any suggestions, I would most appreciate it.
Al?ÿ
Posted : 27/10/2020 12:57 pm
I don't know that I can help. But I do know that there were several "javad radios", and knowing which one you have would be helpful.
I have a 35 watt radio, transmitter, that is made by Pac Crest. It's got a Topcon label. Is this what you have, but with a javad sticker? If so, it may be helpful to treat it like a Pac Crest, and ignore the marketing sticker.
I have another 35 watt radio. It's a product made by AR West. It's a javad, but I'm not completely sure who owns what in this.
Anyway, knowing for sure what you have is going to help.
Post a pic?
Nate
Posted : 28/10/2020 3:48 am
(@big-al)
2A042F83 4F83 4C33 82AD C93E0DCBE3E8
Hi Nate. This is what it looks like. It is an HPT435BT.?ÿ
Posted : 28/10/2020 4:33 pm
(@big-al)
I think I have a pretty good clue as to what's going on.?ÿ The link rate of the Javad 35W radio is FIXED based upon the chosen modulation type (GMSK) and the bandwidth (12.5 kHz).?ÿ I believe the nL400 radio operates on GMSK, and have been unable to set the bandwidth at anything besides 12.5 kHz.?ÿ Therefore, the radio link rate at the Javad 35W radio is fixed at 4800 bps.?ÿ I'm still trying to figure out whether the internal nL400 radio at the rover can receive at this link rate, and if so, how to accomplish this through SurvCE or otherwise.
Posted : 02/11/2020 7:45 am
