Help Reducing Data - Full Station - Spot Elevations
8 Users
(@larryj)
Active Member Registered
@loyal
Yeah.  I figured as much, but needed to ask.
Although we record water level depth to 0.01', the difference in groundwater elevation between MWs is generally much more than 0.1'.  I have seen nearly flat conditions though that require the 0.01 accuracy, and it's always good practice to obtain the best data possible.
Thanks to everyone for all the assistance.
Posted : 21/11/2019 6:08 am
Illustrious Member Registered
@larryj
I don't know what D&R means, or zenith angle...and all due respect, don't really want to know.
In that case you should not be surveying. D&R means Direct Face and Reversed Face. By doing that one can consistently achieve 0.01' elevations with even a $5000 instrument, which I have done for more than 20 years. Zenith angle is a typical instrument setup. The Zenith (directly up) is zero and the horizon reads as 90°. The other setup is Vertical angle where the horizon is Zero and you must record + or - angles, giving greater opportunity for errors.
Is there a relatively inexpensive instrument that will determine elevations to within 0.01' using GPS or other technology besides standard survey equipment.  Not even sure if a $20K GPS system will do that.
Precision requires operator knowledge and proper techniques. Money can buy you some education if you are willing, but does not buy precision.
Posted : 21/11/2019 7:56 am
Share:
