Compare computed points with your stakeout points?
 FLS
(@fls)
How do you get a report on the difference of your XYZ of your stakeout points from the computed point?
Carlson, does note them in the RW5 report?
Thanks
Posted : 13/11/2014 11:07 am
(@roadhand)
SCS Data manager has a pretty slick customizable report
Posted : 13/11/2014 11:15 am
(@djames)
Carlson will also let you set up a cutsheet file .
Posted : 13/11/2014 5:30 pm
(@stephen-ward)
In Carlson SurvCE under Job Settings there's a drop-down list labeled 'Cutsheets:'. I have mine set to 'Auto-Save by Job & Date'. Then switch to the Stake tab at the top and select the Cutsheets button at the bottom right of the screen. This will open the screen where you can customize what you want shown in the different types of cutsheets. It can create separate cut sheets for Point Stakes, Alignment Stakes, Slope Stakes, Grade Stakes, and Story Stakes.
Posted : 13/11/2014 9:58 pm
 RADU
(@radu)
Does your program have point comparison facility? if it does then set up a second job with set out points with same number as original points and then compare two data bases.
RADU
Posted : 14/11/2014 3:53 am
 FLS
(@fls)
Thanks for the input!
Posted : 14/11/2014 5:45 am
(@stephen-ward)
Here's a couple of screen shots of a Point Stake cut sheet and an Alignment cut sheet.
Posted : 14/11/2014 6:08 am
(@francisco)
Yes, you can import the text file to Excel and print later (see attchement)
#Design Pt ID Design Elev Stake North Stake East Stake Elev Cut Fill Desc Stake Pt ID Delta X Delta Y
205 0 4167128.41 336502.91 315.97 315.97 STK205 CUT 315.97 0 0.01
203 0 4167064.88 336112.2 315.02 315.02 STK203 CUT 315.02 0 0.04
34 0 4167306.04 337363 321.12 321.12 STK34 CUT 321.12 0 0.04
215 0 4167446.73 337765.85 315.95 315.95 STK215 CUT 315.95 0.01 0.04
Replanteos Guijarrosa_no todos grabados.xlsx (12.6 KB)
Posted : 15/06/2017 10:12 am
