Carlson compatible
8 Users
(@laboarder)
Active Member Registered
Just curious if anyone is using a robotic total station in conjunction with a Carlson Surveyor 2 data collector. If so what make and model robot
Posted : 09/04/2020 3:41 pm
(@sireath)
Reputable Member Registered
You can check the following link for it. I personally use it on Geomax Zoom 80, 90 without issues
http://survce.com/supportedHardware
Posted : 09/04/2020 7:41 pm
 jph
(@jph)
Famed Member Registered
Leica TS16.?ÿ Works well.?ÿ Does some funky things, but mostly it's things that it's designed to do.?ÿ
Posted : 10/04/2020 5:10 am
(@oldpacer)
Honorable Member Registered
TS 13, works like they were made together.
Posted : 10/04/2020 2:12 pm
(@cooper)
Eminent Member Registered
Topcon PS and ES total stations with no issues
Posted : 13/04/2020 8:43 am
(@russ455)
Estimable Member Registered
Any Sokkia instrument should work fine?ÿ
Posted : 13/04/2020 9:58 am
(@ferg2655)
The Spectra Geospatial Focus 35rx robotic TS is compatible if you looking for a reliable unit with Trimble quality w/o the price.?ÿ
Posted : 25/04/2020 7:03 pm
(@murphy)
Prominent Member Registered
Leica TS 12 works well with a Carlson Surveyor 2.?ÿ The DC has long range Bluetooth which is limited to about 900' line of sight.?ÿ Any amount of foliage will block the signal.?ÿ
Posted : 26/04/2020 7:26 am
Share:
