Calibrating a GPS?
17 Users
(@mmulherncaltecpmcom)
roveryan,
Just wanted to let you know there is a calibration service available for GPS receivers, TS, and Lasers that is traceable to international standards and is from an ISO17025 Accredited lab. I can pass that information along to you if you want to contact me directly, mmulhern@caltecpm.com
Thanks,
Matt
Posted : July 10, 2013 4:56 am
FYI, your website needs some work. "Technical" is misspelled, and all four of the image links are broken.
Interesting business, though. What procedure do you use to calibrate GPS receivers?
Posted : July 10, 2013 5:29 pm
Thanks for the heads up on the problems with our website.
To your question about the test standards we use - we've developed a procedure and master that are proprietary. As a calibration and test lab, the standard we work to is ISO17025. We are regularly audited, proficiency tested, and hold ACLASS accreditation (ANSI) as well as ISO 9001. You can find GPS receivers listed on our scope of accreditation.
Thanks Again.
Posted : July 14, 2013 3:54 pm
