ATV accessories
14 Users
You can mount gun racks with one on the front basket and one on the back basket.
My favorite accessories are PLANO plastic boxes with a lid.
The large one fist on the back and the other on the front, both holding many tools and are rather water resistant.
Posted : 15/12/2020 4:58 pm
(@dave-reynolds)
Reputable Member Registered
I went the rifle-mount route and mounted them on the basket, so the poles would be parallel with the direction of travel - less likely to hang up on the brush. The baskets make it easy to haul most everything I need... instrument, tripods, cones, re-bar, hammer, machete,?ÿ etc.
ATV PHOTO 1
Posted : 16/12/2020 3:59 pm
(@flyin-solo)
Noble Member Registered
Those setups are nice and all, but to be clear: Iƒ??m running topo with the atv, so the gun rack/horizontal option doesnƒ??t cut it for my needs.
Posted : 16/12/2020 4:42 pm
(@dave-reynolds)
The original post was about horizontal mounts and I didnƒ??t notice it was started in 2016. Nice job on your innovation...
Posted : 17/12/2020 12:54 am
(@flyin-solo)
@dave-reynolds
dave, you're correct.?ÿ sorry, wasn't trying to be chippy there.?ÿ and i admit i was being lazy in finding the original thread where this would fit.
Posted : 17/12/2020 5:21 am
(@polerdevol)
New Member Registered
The Polaris Ranger Roof made of high-density plastic for outdoor use. It has a good texture and is durable and impact resistant. It will not age or crack in a few months.
Posted : 02/07/2023 2:48 am
(@olemanriver)
Famed Member Registered
Pre 4 wheelers and before i used rtk more often than not. We welded a oipe on a old ball and had a holder that mounted to the tow hitch area worked great for keeping the rod vertical it was a prism pole. But worked. I rigged one up on a 4 wheeler in 2006 for a guy. He ran around doing continuous topo with a robot. We had it set up so he could get a good target height. I like those collapsing rtk rods instead of the two piece fixed for walking through brush. That would also be nice on a at. As well.
Posted : 05/07/2023 6:24 pm
(@hi-staker)
I bought a 3' piece of 5/8" allthread, which is bolted to the side of our utility basket on the ATV.  A quick disconnect nipple is bolted to the top of that allthread.  We know the measure up to the bottom of the mount and can "ride" topo all day long.  Total cost = +/- $20 bucks for the allthread and u-clamps plus time to install.  Much better than those janky Seco style rod holders and a hell of a lot less expensive.  Survey rod gets clamped in a gun rack on the front of the basket. The user has to adjust rod height if they switch back and forth, which isn't a huge deal as long as you have conscientious users.
Posted : 06/07/2023 2:03 pm
Share:
