What is the DTWIST command now in LDD 2007?
(@ekillo)
I need to view my model space rotated in paperspace so that my road is on the bottom for the small lot I am working on. I usually draw North up and don't use this command much. I need to rotate -30 degrees. I tried the DVIEW but it only works in model space. Thanks for any help
Posted : February 12, 2012 11:33 am
(@stephen-ward)
What is the DTWIST command now?
Switch to paperspace, type MVSETUP, then align, then rotate view, chose your base point and enter your degrees of rotation.
Edit: I didn't see that you were asking about LLD 2007. The above works for LDD2i and AutoCAD 2000.
Posted : February 12, 2012 11:40 am
UCS Z (pick two points along desired orientation) PLAN C VIEW S (enter desired name for saved view)
That's the way us UCS adherents do it. I'm sure the DVIEW practitioners will chime in with their version.
Edit: Works only in model space. 🙂
Posted : February 12, 2012 11:42 am
(@ekillo)
Thanks Stephen, that worked.
Posted : February 12, 2012 11:47 am
(@survey4ya)
north rotation
Posted : February 12, 2012 3:21 pm
(@cptdent)
Use Dviewtwist to align stuff as you want. Save that as a "view". Then in paper space you can set that view in the viewport.
Posted : February 12, 2012 4:24 pm
(@steve-adams)
ditto cap'n dent
Posted : February 13, 2012 9:02 am
