So I know this should be easy, and I am obviously making it hard. But why is it my TSCE Recognizes power coming in com 2 I'm but not the USB or the cat 5 ?
The TSCE has power in on the DB26 and on the LEMO port (assuming your TSCE has a LEMO port, there is a model that doesn't). It accepts 12V just removed link It does not have POE or USB power, just Ethernet and USB removed link What do you expect, it's OLD!
The board seems to think I'm embedding links in this message when I'm obviously removed link I wonder what's up with removed link
Yes it is old.?ÿ But what I do not understand is that the adapter has a network cable and a usb.?ÿ The adapter also has power.?ÿ The adapter is used to charge the tsce.?ÿ If I put a cat 5 in the adapter and physically?ÿ set an up an adress, I can get into my network and get internet.?ÿ But I have been unable to figure out how to get usb to work.?ÿ Was trying to use a usb c cable and attach my phone so I could attempt to put Frank on FPRN.
