TOPCON FC-5000 TOUCHSCREEN ISSUE
(@fmc627)
Eminent Member Registered
The unit boots up fine, but the touch screen does not work. Held power button down until unit shut down and re-started, did not work. Downloaded newest version of software and still does not work. Any idea?
Posted : 05/08/2019 5:23 am
(@rotatenorth)
Estimable Member Registered
Man this is why we switched back to SurveyPro and Spectra. No clue other than itƒ??s Magnet or the FC 5000. We had the same issues and just could not work with it. Best of Luck.?ÿ
Posted : 05/08/2019 7:29 pm
(@russ455)
If you have the latest Windows updates try checking the OS and bios version under DŽ?vice ?ÿinfo to be sure they arŽ? current.
bios version should end in.025?ÿ
OS version should be 19xxx
Posted : 05/08/2019 7:35 pm
(@ladd-nelson)
Prominent Member Registered
You might try the suggestions at the article entitled "TOUCHSCREEN NOT RESPONDING OR ACCURATE ON MESA 2" (I believe a cousin unit to the FC-5000) on the Juniper Systems web-site:
https://www.junipersys.com/support/article/12755
Posted : 06/08/2019 6:17 pm
Share:
