Software, CAD & Mapping
3
Posts
2
Users
0
Reactions
4
Views
I can't get TGO to run in Windows 10. If I drill down to TGOffice.exe then right click and select the Properties/compatibility tab and run the trouble shooter and select Windows 7 as the last version of windows that it successfully ran on I can get it to run a little bit until it crashes. It won't run at all if I select Windows XP.
Anybody have any luck getting TGO to run inside Windows 10?
Posted : December 10, 2015 10:28 am
If it won't run in XP compatibility mode then you're probably not going to be able to get it to run, that was the only way I could get it to run in Win7.
Posted : December 10, 2015 1:41 pm
Yeah, I was afraid that would be the case. Luckily, I'm retired and don't do any real surveying anymore. Just wanted to see if I could make it work.
Posted : December 10, 2015 2:33 pm
