TBC, linking codes, feature library and photo attributes.......THANKS IN ADVANCE !!!
2 Users
(@jrhernan)
HELLO forum,?ÿ
am new to Trimble , but not surveying; i remember using a RedEye attachment on a T-2 (?) Wild....[Leica was much easier]
am also new to employer, company not new but been around;, but still they do not use linking codes or photo attributes.
So can someone please, Please, send me like a dummy feature library that allows photo attributes and has linking codes. it can be a small demo feature library just so i can show guys here how to use linking codes and use the TSC3 photo camera....this would be so much easier here but this place likes to play connect the dots on computer cadd inside the office, i guess they say "its how we always did it....."
i need a small demo feature library so i can see how to either edit or create a new feature library in TBC utilities and then load it into the controller.?ÿ?ÿ
THANKS IN ADVANCE for any reply !!
jrhernan
jrhernan2201@gmail.com
Posted : 21/05/2018 10:56 am
(@lee-d)
I just saw this post. TBC has a sample feature library embedded in the Feature Definition Manager, just go to the File tab, then Tools, and open the FDM (depending on your TBC version, I'm assuming it's reasonably current). Creating features and attributes is very intuitive, and an attribute can be created that is a dedicated photo attribute. And if you process feature codes in TBC, the photos will be embedded in a KML/KMZ export (as an xref).
If TBC is installed on your PC you should have a Feature Definition Manager folder in your My Documents. The sample library should be in there, and it should be called Global Features V##.fxl. Again, I'm assuming your software is relatively current; the current versions are 4.10 for TBC and 2017.11 for Access.
Posted : 24/05/2018 7:59 am
(@jrhernan)
Thanks !!, i will look into that today
joe
Posted : 29/05/2018 4:11 am
