TBC Image Processing?
2 Users
(@brandon-glantz)
I have some images that were taken with an S7 that I would like to see the point numbers on. They are not panoramas, but just single images. I am trying to get an image that is similar to the one you get when looking at the data collector screen when using the data collector to view what the total station is looking at. Has anybody done this before?
Posted : 17/02/2016 3:04 pm
(@alan-chyko)
If you downloaded the *.job file through data transfer, the image files captured by the gun should auto-import into your TBC project. The stations that you took the pics from should have a small camera icon around the point symbol. You can select the point in question, and when the context menu pops up, pick the "Station..." option. You can then right click and select "New Station View" and another tab should pop up with your image. You can then use the filter manager to turn off/on whatever data you want to see.
Posted : 20/02/2016 2:27 pm
