I'm a longtime Topcon user and have had to switch to Trimble.
Here is my dilemma......
I want to export a csv of some staked points for creating cut sheets.
Here is the format I'm trying to create
Design Point, Description, Design Elev, Stake Elev, Cut, Fill
In Magnet I just create a custom report and export it straight from the data collector. Done.
Can this be done in the Data Collector??ÿ
I've found custom reports in TBC but can't get the format I want.
And it's an extra step that really isn't needed if the data collector can do it.
All running Trimble Access and the newest TBC on my office PC.
TIA!!!
Bo
The DC should be able to do it, you may have to upload a style sheet to get the format you're looking for.?ÿ Try looking here Trimble Downloads?ÿunder?ÿ the Style Sheets heading, it may be under the General Survey Style Sheets or possibly Style Sheets for As-staked Deltas Display.?ÿ There's also documentation there on how to create a custom style sheet if need be.
Excellent.
This will get me started.
Thanks!
Also in TBC go to your Export Format Editor and look at your export options under As-Staked Point. However, for stakeout exporting / reporting to work properly, the points have to be shot as as-staked points; in other words, the crew shouldn't toggle over to Measure Points and shoot them as topo.
It only took me 3 months to get what I wanted. I ended up writing the code from 3 other reports that had what I wanted.
Now I get As-Staked Point, Design Point, Design Elev, Stake Elevation,Cut/Fill
Our Trimble rep tried but was not able to get the data to format correctly. In the process I've learned to code style sheets.
So if ya need something customized I may be able to help.
I'm looking for something similar -> As staked report (showing an inverse between design, as staked point) PLUS an inverse from design to a checkshot. Is this possible?
