Survey Project vs Project Explorer (Microstation GEOPAK)
1 Users
(@headywest)
Power GOEPAK v8i (SELECT series 4) Version 08.11.09.851
Former InRoads user and I am now using GEOPAK. Creating a surface for others to design from.
I need to create horizontal alignments from point numbers for creek cross sections. I have used the Horizontal Geometry tools and Vertical Geometry tools from the Survey Tasks menu to cut profiles from my surface. My client wants me to use actual shot points rather than surface data to create the profiles. I tried the 'Complex by Element' workflow and it works but the output is not what I want to see.
I attempted to use the GEOPAK>Survey tools to create lines from points but I keep getting the error message that there are no points in the current project. When I use the Project Explorer I can see the field book and the properties show all the points.
I attempted to export the field book but I can't work out how to import the file to the Survey Project and, to be honest, I am not sure why the Survey Project is different from what is in the Project Explorer.
Obviously, I have hobbled together a way to make the project work up to this point but some guidance on how these work together and what I missed or messed up would be very appreciated!
Posted : 08/08/2016 10:52 am
