Rotating view in paper space without affecting coordinates
15 Users
Famed Member Registered
Can anyone walk me through the steps using the UCS command to rotate my paper space viewport to orient my view of model space in Carlson Survey/Intellicad 10.1? I've messed around with it but afraid of blowing something up while I'm completely slammed on some huge jobs I need to get staked in a very short period of time. TIA.?ÿ?ÿ
Posted : 15/06/2023 8:47 am
(@ozzy84)
Estimable Member Registered
view -> twist screen
standard = lets you "rotate view" dynamically
line, polyline, text= lets you pick object to "rotate view"
surveyor = lets you key in azimuth
none of above will change coordinates, experiment with copy of drawing.
Posted : 15/06/2023 9:17 am
(@learner)
What Ozzy said.  Run away from UCS!
Posted : 15/06/2023 10:34 am
(@peter-lothian)
Noble Member Registered
UCS is the spawn of the Devil. Follow the righteous path, and use DVIEW > TWIST.
If you want to use ORTHO (F8) for linework and text orientation across the screen, set SNAPANG to the negative of your dview twist angle.
For example:
DVIEW > TWIST > 35
SNAPANG > -35
Posted : 15/06/2023 10:56 am
Thank you for the help all. I'll give this a go in the am. Right now I'm so tired I can't think straight.
Willy out.
Posted : 15/06/2023 4:55 pm
Way too much information.......................
"Willy out."
https://chicago.eater.com/2022/9/23/23368403/willies-n-waffles-x-rated-shop-sundae-stop-chicago-boystown-gayborhood-closing
Posted : 15/06/2023 6:08 pm
Illustrious Member Registered
IMG 7524
Look who is here!
@scott-zelenak
Posted : 16/06/2023 4:03 am
(@ars-mine-surveyor)
Trusted Member Registered
I don't know how it works in Intellicad, but in Carlson with autocad the easy way is to go to
View, Twist Screen and Line or polyline and pick the line that you want to be horizontal in the viewport. It will not change anything else.
I usually twist both model and viewport to the same line.
Posted : 16/06/2023 4:39 am
 rach
(@rach)
New Member Registered
UCS > OBject [OB] > [select an object]
Plan > [Enter] > [Enter]
This will rotate UCS
Plan > World [W]
UCS > World [W]
These or combination of these will restore your view
Posted : 16/06/2023 9:50 am
(@va-ls-2867)
Honorable Member Registered
Plan > World [W]
UCS > World [W]
Do not use the ucs rotate, that changes your coordinate system.  Use twist screen options in Carlson or DView option in Autocad
Posted : 16/06/2023 6:12 pm
(@not-my-real-name)
Noble Member Customer
I use UCS, but never in the same drawing as the model. What I do is XREF (attach) the model I want to rotate into a new drawing, and create paper space viewports. Switch to model space in any of the viewports, and rotate the UCS Z axis. This gives me a drawing I can print for presentation. I would only calculate coordinates in the original drawing of the model.
Posted : 17/06/2023 4:03 am
(@cv)
Estimable Member Customer
@williwaw  I will have to try some of the commands listed above. Personally, I use "MVSETUP"
Posted : 17/06/2023 5:43 am
(@cv)
MVSETUP allows me to rotate the viewport angle with no affect to the UCS.
Posted : 17/06/2023 5:46 am
Very helpful thread. Big thank you to everyone.
Posted : 17/06/2023 9:07 am
(@chris-bouffard)
It the plan was generated on your original survey coordinates use WCS and your points will drop right in where they belong.  This is a common problem when drafters rotate their views for what is convenient to them.
Posted : 17/06/2023 2:00 pm
Share:
