Having difficulty printing to a new multi-function office copier/printer from Autocad 2015
I only get about 1/2" of my page printed. The rest is blank.
I have tried the print server driver (PCL6), a locally installed PCL6 driver and a locally installed PCL driver.
All of the drivers result in the same partial print.
Anybody else had this problem?
Through Google, I have managed to determine that it is the transparency setting in Autocad that is causing the issue.
Have not found out how to get it to print with transparency yet.
In the print dialogue there is a check box for printing transperancy on the right side also in the print page setup, I think. That is the only place I know.
Sent from my SM-G925V using Tapatalk
Scotland, post: 377719, member: 559 wrote: In the print dialogue there is a check box for printing transperancy on the right side also in the print page setup, I think. That is the only place I know.
Yes, if I toggle that setting on, the printer will only print 1/2" of the page. Toggle it off and it works fine.
